Has anyone replaced Torque converter solenoid on Discovery 2?
Old Jan 27, 2017 | 09:51 AM
dconnor's Avatar
Default Has anyone replaced Torque converter solenoid on Discovery 2?
PO741 code indicates problem with Torque converter solenoid. Does transmission have to be removed to replaced solenoid?
Old Jan 27, 2017 | 01:44 PM
OffroadFrance's Avatar
I don't know for sure but try Abran Abeyta or Paul Grant for one and also ask them the question.
Old Jan 27, 2017 | 03:14 PM
number9's Avatar
D2 manual:
P0741 * Torque converter lock-up clutch fault
May affect driveability.
Trans manual:
The software has detected a potential problem with the torque converter system.
Do you have any symptoms to warrant solenoid replacement? Can the code be cleared? Does it immediately return?
Not necessary to remove trans to replace.
Old Jan 27, 2017 | 07:34 PM
dconnor's Avatar
Originally Posted by number9
D2 manual:
Trans manual:
Cannot identify any symptoms associated with code appearing. It has appeared twice with over 100 miles between codes. Both times with heavy weather conditions (major snow storm and second time heavy rain). Tran fluid looks good in color aND level. My code reader says solenoid locked off. Replaced torque converter in 2013. Good to know that am not looking at pulling transmission. Thanks
cobbcj7
Dec 13, 2019 06:12 PM
ThatFastGuy
Jan 5, 2014 08:11 PM
twaszak
Jun 27, 2011 01:32 PM
jared
Dec 20, 2007 06:51 AM
