Have you siphoned gas from your D2?
Old Jun 7, 2013 | 09:58 AM
SuperSport's Avatar
Originally Posted by drowssap
disconnect the fuel line anywhere after the tank and turn the key on.
Won't it only run for a moment since the engine is not running? The computer should turn off the flow without a running engine shouldn't it? At least on my Jag it was that way.
Old Jun 7, 2013 | 10:06 AM
drowssap's Avatar
your probably right. any good jag forum have issue with an S-type I just picked up
Old Jun 7, 2013 | 11:24 AM
Dan7's Avatar
THIS IS NOT A METAPHOR!!! I think you can turn to ignition to position 2 as many times as you want. Not sure how much would pump out each time you toggle the key though.
Old Jun 7, 2013 | 11:25 AM
SuperSport's Avatar
My Favorite: www.JaguarForums.com I'm also SuperSport over there.
Old Jun 7, 2013 | 11:33 AM
You could jump the fuel pump relay contacts and have constant run.
Old Jun 7, 2013 | 11:54 AM
SuperSport's Avatar
So, there's no way to push a siphon hose down there? I have not tried yet, but my Jag was fine with it, and they are very close cousins.
Old Jun 7, 2013 | 02:32 PM
caymandrew's Avatar
Looks like Mike is right. I just tried it, I can get about 3 feet of hose in there before it jams up on something. Couldn't siphon a drop.
DiscoPhipps78
Jun 13, 2019 04:09 PM
gillart
Feb 23, 2015 12:26 PM
calebbo
Oct 12, 2011 09:54 PM
mge_1
May 6, 2006 07:46 PM
