HD Axle Inspection
Old Mar 30, 2024 | 03:14 PM
rikkd's Avatar
Default HD Axle Inspection
While replacing the CV boot I noticed some rust and wear on the half shaft. This is the front driver half shaft. Should I be concerned with either? Should I sand down the rust?
Wear
Rust
Old Apr 1, 2024 | 09:47 AM
Harvlr's Avatar
The rust on the axle looks pretty superficial to me. A light sanding would be fine. It looks like the axle sat without turning for a while. I would certainly reuse it.
Old Apr 2, 2024 | 08:34 AM
The_OGCJR's Avatar
That’s a mere flesh wound! Seriously, Id scrub with a green pad and water (no chems) coat it with diff fluid and re-install
Droog
Nov 22, 2023 08:51 AM
jonlenoury
Defender
Mar 13, 2022 07:42 PM
boiseboardboy
Defender
Jan 12, 2021 05:26 PM
Corbin Lauvray
Dec 25, 2020 03:36 PM
LR03NJ
Mar 20, 2016 06:37 PM
