Head bolt question
Old May 30, 2018 | 06:44 PM
328Driver's Avatar
Default Head bolt question
Do the headbolts on the discovery go into the water jacket or are they dry?
Asking if I have to put sealant on the bolt threads. Thx
Old May 30, 2018 | 07:59 PM
PalmettoDisco's Avatar
Download and read the (free) RAVE factory service manual on installing the heads. Manual states TTY head bolts should have a light coat of oil for accurate torque procedure .
Old May 30, 2018 | 10:07 PM
328Driver's Avatar
Thanks. I have read the manual. Making sure I wasn't missing something.
Old May 30, 2018 | 11:28 PM
No Doubt's Avatar
I think that I applied a sealer to the end head bolts (well, studs for me)? Hard to remember. I was thinking that the end studs *did* go into the water jacket.
On the studs I used loctite, and on the end studs I used loctite on the bottom of the studs and sealer on the top few threads.
You don't oil the ARP studs (maybe different for actual OEM head bolts??), but you do use precision torque grease on the nuts and 1 side of the washers that go onto head studs.
Old May 31, 2018 | 12:00 AM
abran's Avatar
They are dry
Old May 31, 2018 | 12:05 AM
Saturnine's Avatar
I just dipped the head bolts in fresh oil before installing them
Old May 31, 2018 | 05:29 AM
shanechevelle's Avatar
Atlantic British has videos on their site. Watch the head gasket install video.
Old May 31, 2018 | 09:18 AM
328Driver's Avatar
Cool. Thanks for the replies. I'm gonna check out the video at AB since I'm putting in studs. Another thing is what are ya'll's opinion on putting rtv on the front cover gasket?. Manual says dry but I've read about several people doing it with success.
Old May 31, 2018 | 02:36 PM
Sixpack577's Avatar
Ultra black rtv, on the oil pan, timing cover, and valve covers. By the instructions/cure time before adding oil.
A small even bead on both sides of the gasket.
I also retorque all the bolts after about an hour.
Old May 31, 2018 | 04:31 PM
328Driver's Avatar
Thanks sixpack
