Head bolt question
I think that I applied a sealer to the end head bolts (well, studs for me)? Hard to remember. I was thinking that the end studs *did* go into the water jacket.
On the studs I used loctite, and on the end studs I used loctite on the bottom of the studs and sealer on the top few threads.
You don't oil the ARP studs (maybe different for actual OEM head bolts??), but you do use precision torque grease on the nuts and 1 side of the washers that go onto head studs.
Cool. Thanks for the replies. I'm gonna check out the video at AB since I'm putting in studs. Another thing is what are ya'll's opinion on putting rtv on the front cover gasket?. Manual says dry but I've read about several people doing it with success.
