Head Bolt Torque Value in ft-lbs
There is no actual torque value to my knowledge. You have to do the 15lb then wait then 90 degrees them wait then 90 degrees. That allows the head bolt to slowly stretch so it doesn't break and surpasses difference in friction issues like temperature and whether there is oil anywhere that there would be friction against the bolt.
UPDATE:
Trust me, I have taken the time and I have read and followed the RAVE.
My issue here was that while teaching helping my son learn to work on the DiscoII, he and I and we were not sure if he performed the last 90 degree torque on the number 5 bolt in the LHS head sequence. That was a question. Instead of just doing another 90 degree or risking that the #5 would be missing the last 90 degree I wanted a way to help determine if the #5 was indeed torqued 90 twice. The obvious alternative of course would have been to remove all bolts, order a new gasket and new bolts, wait a week and try again. Instead I determined from the #9 bolt in the sequence (we knew it had been turned twice) that the torque value was 80 ft lbs. I then put the torque wrench on #5 and indeed the bolt held to 80 ft lbs before moving ever so slightly. Now I can sleep better.
Thank you all.
Thank you all.
twin6 (02-07-2017)
UPDATE:
Thank you all.
Thank you all.
twin6 (02-07-2017)
