Head bolts?
I'm in the process of doing a head gasket replacement and for the life of me I cannot get the head bolts out. Specifically the first one in the sequence. Any suggestions? I've broken ratchets, tried cheater bars, breaker bars, etc. it won't budge. Help!
a shallow 6 point 5/8 inch impact socket with a 4 inch extension and a 25 inch breaker bar should do it. of course it helps if your more then 90 pound also
. if need be you could put a cheater bar on the breaker bar but it should not be needed. Ratches are not made to that that much toqure and will usually breaker. the hole setup will cost like $30.00 at habor freight or $100.00 at sears.
Worse case if you can't get it out... At the dealership when we round off a head bolt we use a air powered angle grinder with a carbide or some type of bur bit and just grind the head off the bolt. You can remove the rest after the head comes off. Just be sure to cover the engine and use a lot of rags to catch metal debris. If you don't have a source of air to run an angle grinder you can probably use a dremel tool. Either way grind the head off. No biggy.
