Which Head Gasket? Composite or Shim?
Old Apr 18, 2010 | 10:28 PM
audiS4S6's Avatar
Default Which Head Gasket? Composite or Shim?
I see the Atlantic advertises head gaskets as "composite" and they also seem to offer a standard type gasket. Do I want the composite ones?
I plan on ordering most parts from my regular foreign car parts source - fap99.com. The prices are about 1/2 of Atlantic but they do not offer the composite head gasket.
Thanks,
Dave K.
'95 Disco with blown head gasket (s)...
Old Apr 19, 2010 | 06:11 AM
lipadj46's Avatar
I've only seen and used composite head gaskets. Most people use composite I believe also they give you a little head space when you get the heads planed down flat.
Old Apr 19, 2010 | 07:19 AM
vandev's Avatar
Default other brand
I havent talked to this company but on a another rover forum someone wrote:
Cometic recently, and they now have 4.0/4.6 MLS gaskets!
If these things can seal up a 7500 horsepower top fuel engine running 70 pounds of boost, they'll seal up our 9.5:1
Wouldn't hurt to find out thoe.
http://www.cometic.com/
Good luck, Chris
Old Apr 19, 2010 | 08:07 AM
TinSoldier's Avatar
7th Gear
i have used Cometic in my racing engines in the past and it held everything I threw at it. However the key thing in any good gasket is to make sure the mating surfaces are flat.
Old Apr 19, 2010 | 01:43 PM
audiS4S6's Avatar
Good luck, Chris
I put an inquiry in. I'll report on what I hear...
Dave K.
Old Apr 19, 2010 | 02:04 PM
IBA 270's Avatar
+1...nothing else matters if you don't have this condition.
Old Apr 19, 2010 | 08:21 PM
audiS4S6's Avatar
I thought that was obvious...
Old Apr 22, 2010 | 08:51 PM
audiS4S6's Avatar
I got a quote of $100 EACH for these head gaskets. Thinking about it...
RicketyTick
Jun 7, 2014 10:37 AM
ImQuattro
Mar 24, 2014 10:26 AM
rasch_C
Dec 22, 2012 01:47 PM
kylelind
Mar 4, 2011 12:30 AM
handsome rob
Jun 17, 2009 12:35 AM
