head gasket/oil gears - parts list?
Old Apr 1, 2010 | 10:19 PM
A_J's Avatar
A_J
Default head gasket/oil gears - parts list?
Getting ready to order parts for the head gasket and oil pump gears, but wanted to get a check on the parts, and any suggestions people have. It's an 03 in the VIN range, getting low oil pressure, and I have significant lifter/rocker noise. I have not had the oil pressure tested in a while, but last time I did, it was low but I don't remember the numbers. oil light is not come on though that's not saying much.
So, parts from atlantic british:
head gasket kit
head bolts
oil seal (front cover)
front cover gasket
oil pump gears
oil sump gasket
oil cooler o ring
oil pickup o ring
t-stat and serp belt for good measure
for the lifters/rockers, I'm assuming worn parts in there, but I won't know until I get it open what I need, so I'll order later. I'm thinking couple of stuck lifters and/or worn push rods.
Questions:
1) anything to add to the parts list?
2) any tips on finding out which lifters are bad or should I assume all are bad and replace?
3) same question on rods - should I replace all if a few are bad?
4) anything else I should think about replacing while I have the whole thing open?
Thanks in advance
Old Apr 2, 2010 | 08:41 AM
AJ,
Send me your tele number and lets talk.
LandRoverDisco03
Jan 16, 2015 10:04 AM
LeakyDisco
Jul 8, 2012 10:57 PM
Robwsup
Mar 11, 2010 10:28 PM
lipadj46
Jun 17, 2009 08:41 PM
RoverRover1
Jun 1, 2009 09:37 AM
