Head gasket replacement
Old Dec 24, 2013 | 07:18 AM
  #61
jfall's Avatar
Did you properly bleed the cooling system?
To do that all in one day is incredible to me.
Took me two weeks in a parking lot.
Old Dec 24, 2013 | 09:21 AM
  #62
Charlie_V's Avatar
I bled the cooling system and changed the oil. I also had to replace power steering fluid from removing the pump. But no, it didn't take me a day. It took three days in total. At least, it was three days from the time I parked the Rover in the garage and pulled it out again. And I had help about half of the time. Also, I did it over the weekend plus half Friday and half Monday. I did waste some time dealing with boogered exhaust flange studs, trying to figure out why I didn't have enough head bolts, and just in awe of seeing the inside of my engine. Also, I was slow by monsoon rains that partially flooded my garage Saturday night and Sunday. But I don't think I could have done the actual work a lot faster.
Old Dec 24, 2013 | 09:23 AM
  #63
Charlie_V's Avatar
If I did it again I am sure it would be faster... Maybe 30 percent. But I do not believe some of the comments I have read elsewhere claiming that the HG replacement was done in six hours or even a day. Of course, I am not a mechanic, but I did have a workspace and my tools and parts all laid out. I have air tools but I don't use them much and didn't on this project. I don't see how one person could do it in six hours, even nonstop.
Old Dec 24, 2013 | 09:25 AM
  #64
Charlie_V's Avatar
Originally Posted by drowssap
see now that you have burns and cuts, you deserve to own a LR.
you might want to borrow a pressure tester again to check for leaks in a few days. I would hate to see it over heat from a small leak after all you have done.
That's a great suggestion. I have never used a pressure tester but I do know where to rent one locally and am going to do so.
I almost don't want to know... Eek.
Old Dec 24, 2013 | 09:31 AM
  #65
drowssap's Avatar
remove your recovery tank cap, install the pressure tester and pump to 18 psi.
if after 20 minutes you still have 18 psi your go to go, if not you have a leak.
Old Dec 25, 2013 | 10:15 PM
  #66
Charlie_V's Avatar
I've never used a pressure tester. Is that all there is to it? You are talking about the relief tank for the radiator? I don't really understand how that works... But doesn't it have a tube that pours out (is open)?
Old Dec 27, 2013 | 08:30 AM
  #67
drowssap's Avatar
by using the correct adapter you will block off the return line in the top of the recovery tank. then by building pressure up behind the coolant you will force it out anything that is leaking or lose. I'm sure u tube must have a video that someone has already made.
Old Dec 28, 2013 | 08:55 AM
  #68
Charlie_V's Avatar
I need a little more advice...
I did change the gasket and swapped the rocker assembly for a clean one. Of course I cleaned everything during the gasket change. I am getting a misfire on 4,6,and 8 under heavy acceleration only. I don't think it is the gasket because I am not losing coolant and though I let it sit for two days it started right up.
So my thinking is to work my way back from the cylinder. I put new bosch platinum +4s in. Now maybe swap the plug wires from one side to the other. If no joy, then swap the coils (I have an extra set for my spare engine. If that doesn't fix, then fiddle with the injectors.
Is this the right track?
Old Dec 28, 2013 | 10:09 AM
  #69
Charlie_V's Avatar
Has anyone found a way to relocate the coils? Such a PITA.
Old Dec 28, 2013 | 12:00 PM
  #70
Charlie_V's Avatar
Okay I don't think it is the head gasket and am totally mystified. I switched the wires for 7 and 8 and drove like a maniac on the highway and could not replicate the problem. The stuttering was extremely dependable and easy to force, and it is gone. Drove 20 miles. I have no idea. But when I returned I carefully opened the overflow tank and could not smell any exhaust in the fluid. Stumped. Fixed apparently by swapping one wire.
Anyway, if it is not the head gasket this thread is done. Once again, thanks for all of the advice and help.
