Head Gasket Sealant
Old Jul 3, 2013 | 08:56 PM
FlyingZebra34's Avatar
Default Head Gasket Sealant
Anyone use any extra sealants on there head gaskets? I heard the dealerships use hylomar around the water jackets on the head gaskets.
Also on the valley pan gasket, plus the 2 end seals, should any RTV be used?
Old Jul 4, 2013 | 12:24 AM
Certainly the four corners of the "lip" seals. I have the HG head work done, no extra sealant, and am reworking the intaKe/valley pan (bolt stripped out). Will add to my posts in a few days. The valley pan no wanna line up so good.
Old Jul 4, 2013 | 01:35 AM
Well Crap. I didnt get any responses so I put the thing in dry. It's only at 15ftlbs right now. Any recommendations?
Old Jul 4, 2013 | 06:50 AM
You never put any form of sealant on a head gasket unless you are old school and use Copper Spray on the head side only which I do.
If you are wanting to make sure your head gaskets hold up take extra time when installing/torquing the head bolts and make sure to use head bolt thread lubricant on the bolts, nothing else, so you get a uniform torquing across the heads.
Old Jul 4, 2013 | 12:59 PM
Thanks Mike, I was panicking over here.
Old Jul 4, 2013 | 04:43 PM
jfall's Avatar
Never sealant on a head gasket.
Unless you want to invite failure to dinner and then you will
need to do it again - and NOT use sealant.
Hylomar - I would not use it either.
I would use Permatex non hardening
or aviation gasket sealer ONLY on the valley gasket and the rubber U's on front and back of block.
JumPeR04
Nov 23, 2020 07:53 AM
lipadj46
Aug 27, 2012 10:06 AM
ngarover
Apr 16, 2012 09:48 PM
zukilj20
Apr 16, 2012 10:46 AM
JimScream
Jan 6, 2009 02:01 PM
