Head Gaskets Leaking
Old Nov 26, 2008 | 07:35 PM
ne1949mozda's Avatar
Default Head Gaskets Leaking
hi, just wonder what will cost me to fix?
2003 Discovery
thanks!
Old Nov 26, 2008 | 07:38 PM
Default RE: Head Gaskets Leaking
how much cost to fix it? it is left one
2003 Discovery
Old Nov 26, 2008 | 07:52 PM
AK Rover's Avatar
Replace both head gaskets at the same time. If the other ons isn't bad now it will be shortly. Save yourself the time and money and fix both at once. If you take it to a mechanic, a good mechanic will not only replace one. I have to have the head gaskets on my D1 replaced and my mechanic quoted me $1500 for parts and labor.
Old Nov 26, 2008 | 08:05 PM
mechanic told me it will be around $1600 for parts and labor.the one thing I dont know if price for one or both? if he/mechanic fix one Head Gasket for $1600.would be this expensive?
Old Nov 26, 2008 | 08:59 PM
$1600 for one head gasket replacement is twice what it would it should cost.
$1600 for BOTH is a fair price.
Ask him what he is going to do, both or just one. If he says just one then find another shop.
Old Nov 26, 2008 | 10:12 PM
ok i will call him and ask.thanks for information spike!
Old Nov 27, 2008 | 12:27 AM
AK Rover's Avatar
I think not only would I go to another shop but I would probably be tempted to beat the crap out of a mechanic that would only replace one head gasket, especially at that price. As I said earlier, my mechanic quoted me $1500 and I know that is for both head gaskets.
I will say that I could be wrong and replacing one head gasket may be an acceptable practice but I have never heard of it.
Old Nov 27, 2008 | 12:34 AM
Urban Panzer's Avatar
are you 100 % sure its the headgaskets leaking and not the valley pan gasket. When you say left side, do you mean as your sitting in the truck, or looking at the engine ?
If its when your looking at the engine, I would bet its the valley pan gasket, it leaks at the back left corner and drips down onto the bell housing.
Old Nov 27, 2008 | 12:40 AM
AK Rover's Avatar
Is it common for these coolant leaks to pop up at the beginning of winter like this. Seems like a whole mess of posts dealing with coolant leaks have popped up on here in the last week or so. Maybe it's because my Rover is sitting at home waiting for a new water pump and head gaskets that I've just noticing them more.
Ne1949 - Have you had a pressure test performed on the cooling system to verify exactly where the leak is? UP could be right (it has happened) and it could be the valley gasket and not a head gasket.
Old Nov 27, 2008 | 08:24 AM
Considering your 03 has secondary air, $1600 is a fair price to replace both head gaskets. There may be some additional cost if the engine was overheated and warped the heads, apx $200 more.
Make sure they only use Rover gasket kits and new head bolts, apx $210 in total.
Gordon Bombay
Dec 22, 2009 10:31 AM
c0smo kram3r
Feb 17, 2009 07:59 PM
dragon_avaloch
Mar 20, 2008 08:29 PM
jcostello
Nov 2, 2006 10:28 PM
