done with head gaskets... coolant leaking everywhere
Old Dec 21, 2009 | 06:15 PM
Gordon Bombay's Avatar
Default done with head gaskets... coolant leaking everywhere
i got done with my head gasket replacement about 5am this morning. filled it with engine oil. then filled it with coolant and within 15-20 mins every bit of coolant had leaked out and i have no idea where it came from. the last shop that worked on it pretty much screwed me over. it overheated and they were supposed to fix all the coolant leaks and put in a thermo. upon start up, they told me i needed head gaskets so i decided to do that myself to save some $... now i have multiple (guessing) coolant leaks that were supposed to be fixed but weren't.
i havent had a chance to look over it again, but any ideas where they could be coming from?
Old Dec 21, 2009 | 06:26 PM
hilltoppersx's Avatar
you need to clean everything. and add some dye to the coolant so you can find where the coolant is coming from it can be coming from anywhere we won't be able to help you. or you need to find a new mechanic and have it pressure tested. just don't drive it anywhere if it is leaking that bad or you will do some serious damage.
Old Dec 21, 2009 | 06:39 PM
lipadj46's Avatar
I'm not sure how you can lose your coolant in 15 mins and not see where it is leaking, especially after you did all that engine work and know the engine well by now.
Old Dec 21, 2009 | 07:59 PM
Suede's Avatar
You did use a torque wrench AND tighten the head bolts in sequence?
Old Dec 21, 2009 | 08:58 PM
yes i did everything correctly using a calibrated torque wrench and following the D2 workshop manual. im gonna get a pressure check done on it with a NEW mechanic
Old Dec 22, 2009 | 08:48 AM
oysterhead's Avatar
i bet it's a hose, not gaskets, if its leaking at that rate.
Old Dec 22, 2009 | 10:29 AM
exactly what i was thinking because i never started it. therefore the coolant wasnt circulated through the block or heads right?
Old Dec 22, 2009 | 10:31 AM
Did you use new head bolts?
glassman66
Jul 17, 2012 08:31 AM
rcrosby
Jun 25, 2011 12:04 PM
armored
May 30, 2011 07:07 PM
kman3786
May 5, 2009 07:56 PM
kjordan
Oct 22, 2008 08:21 AM
