Head Gaskets Replaced - water in crank case
Old Jul 18, 2019 | 03:11 PM
bjordan's Avatar
I lost some coolant. When I changed the oil, it was full. Now, the level is about 3/8" above the full level mark on the dip stick.
Yes, he can check compression and so can I (from my vintage motorcycle racing days). We will add that to the list of things to try.
Old Jul 18, 2019 | 03:12 PM
bjordan's Avatar
Originally Posted by Red5
Where exactly did you see the water, and how much?
We see it in the discolored oil, and its now about 3/8" above the full mark on the dip stick
Old Jul 18, 2019 | 03:33 PM
CollieRover's Avatar
No coolant on the back of the engine near the heads and lower intake? The gasket looks good on visual inspection?
Old Jul 19, 2019 | 08:34 AM
bjordan's Avatar
No external coolant leaks and head gasket looks fine - from what I can see of it.
Thanks for all the help so far! Will get a coolant pressure test done and possible compression test done this weekend when we both can get some additional eyeball time on it..
Old Jul 19, 2019 | 09:19 AM
It's not easy to see, but it's hard to imagine it is anything but a cracked block, but I am no expert. I got a new engine at 120k, because of an overheat and cracked block, the shop didn't test the block, and that sort of cornered me into a new engine.
Old Jul 19, 2019 | 10:20 AM
bjordan's Avatar
Thanks. I didn't own it when the head gasket went south, but it didn't have any water in the oil when I got it. We'll see what we find this weekend.
Old Jul 19, 2019 | 05:26 PM
FlyingZebra34's Avatar
The valley pan gasket can leak coolant into the engine oil. The front cover gasket can also leak coolant into the engine oil. I'm all for doom and gloom but check your bases first.
Old Jul 19, 2019 | 07:39 PM
shanechevelle's Avatar
The biggest thing people forget is to change the oil after a head gasket job. I see you did that.
Did you take the front cover off?
mydisco03
Jan 11, 2010 02:21 PM
johnkbl
Dec 8, 2009 07:52 PM
ChanchoVerde
Aug 27, 2009 08:03 AM
disco588
Apr 27, 2009 04:12 PM
fatboyx9
Aug 26, 2008 07:16 PM
