Discovey 1 trouble, leaking coolant
Old Jan 11, 2010 | 12:33 PM
mydisco03's Avatar
Unhappy Discovey 1 trouble, leaking coolant
Hi there!! I'm posting this for a friend.. The weether was around 15* with only water on the radiator, He crank the engine early in the morning and now the right side of the engine is leaking water, betwen the head and engine block. What's the problem here? crack head or block? or just the head gasket? this a 98 disco 1 with 100.000 miles
Old Jan 11, 2010 | 01:47 PM
lipadj46's Avatar
Probably a head gasket, he did not overheat it and drive it correct?
Old Jan 11, 2010 | 02:17 PM
mydisco03's Avatar
Never over heat. He just crank the engine in the morning with out antifreeze just water on the coolong system and it was really cold 15* or less....
Old Jan 11, 2010 | 02:21 PM
lipadj46's Avatar
Ah I thought that is what you meant but the title says coolant. Maybe he popped a freeze plug. That would be a best case scenario. But if he is seeing water coming from the head gasket area well that is not good, he is going to have to tear it down and see the damage.
rally1
Feb 22, 2022 06:22 AM
Matt_Attack352
Jan 13, 2014 09:55 AM
christians1600
Jul 9, 2010 05:53 AM
dieselgeek
Jan 19, 2009 07:41 AM
ajusaf
Feb 21, 2008 09:21 AM
