Head Removal on 99 SD2? Anyone done this, tips?
Old Jul 2, 2008 | 07:05 AM
twilightcall's Avatar
4wd High
Default Head Removal on 99 SD2? Anyone done this, tips?
I am going to remove the heads on my brothers 99 SD2. It needs a complete valve job. I was wondering if anyone has done this job on this site and what it was like. I have removed heads on other cars but never a Rover. Any tips or info would be greatly appreciated. Is the Factory workshop manual the best for the procedure or is there another manual that explains the details of the head removal better? Thanks.
Old Jul 2, 2008 | 07:47 AM
DiscoJag's Avatar
Default RE: Head Removal on 99 SD2? Anyone done this, tips?
I did it on my D1, and it wasn't too bad. The factory workshop manual worked for me. Make a holder out of cardboard to put all the pushrods in so you don't get them mixed up, same with the lifters. I soaked my lifters in Marvel Mystery oil while the heads were out getting done at the machine shop - this will clean them and keep them quiet. Buy new head bolts, they stretch and should not be re-used.
Take pictures w/digital camera. Write down what you do after every step and try not to take apart things that you don't have to, and of course buy a set of good quality gaskets. Take your time. You don't want to have to pull the heads again !
Old Jul 2, 2008 | 09:32 AM
How many miles on it and why does it need a complete valve job??????
Old Jul 2, 2008 | 12:38 PM
4wd High
over 100K miles. it is missing and having lots of issues. many cylinders aremissing and has valve noise.
Old Jul 2, 2008 | 03:29 PM
I wouldn't go jumping into something you may not be familiar with.
D2's don't get into valve issues till up around 200,000 miles. internal noises are common and easily fixed then do a goo tune up.
If you don't believe me do a compression test.
Old Jul 2, 2008 | 11:20 PM
CandiMan's Avatar
The long block is the same between a 4.0 and 4.6 so I assume the under hood clearance will also be the same. With that being said, my only advise is to get a 1/2 drive 5/8 universal socket. Not a seperate 5/8 socket with a universal attached. Also a 1/2 drive 3" extension. On both heads, the head bolts closest to the firewall will be a challenge. I read a post where someone suggested unbolting the motor mounts so you can shift the engine around for extra clearance. For me I did not go the motor mount route, but if it was not for these two tools I would have been out of luck.
Have fun
glassman66
Jul 17, 2012 08:31 AM
GamecockRover
Jul 16, 2012 02:00 PM
kfx4001442
May 18, 2008 09:50 PM
Panama Jack
Nov 14, 2007 09:14 PM
alpinab7
Nov 29, 2006 11:27 AM
