Head Resurfacing, How Many Times?
Old Nov 3, 2018 | 08:47 AM
  #21
shanechevelle's Avatar
https://www.bobistheoilguy.com/forum...&Number=563163
Old Nov 3, 2018 | 09:06 AM
  #22
Saturnine's Avatar
Hmm.. i used scotchbrite on the block
Old Nov 3, 2018 | 12:32 PM
  #23
horrible.
except...if you did it when it was disassembled and then washed it ect...you may have gotten it all.
if you did it assembled....oye vey
Old Nov 3, 2018 | 12:55 PM
  #24
Alex_M's Avatar
Huh, news to me on the scotchbrite. I've used them on a couple engine refreshes and they're still going strong, but I reckon time will tell. I've always been real picky about making sure I never leave any abrasive dust from anything behind though, and it's always used with carb cleaner or wd40 so there's no dust flying everywhere; it gets suspended in liquid.
I stand by what I said about the finish though. Milling the heads leaves a similar finish to a sanded head (if the feed rate was slow enough), and is still rougher than a scotchbrite cleaned head. Which leaves a pretty smooth finish. Maybe don't use the scotchbrite on the block (though I've done it...), But the head should be fine as long as it's thoroughly cleaned which I do every time.
Old Nov 20, 2018 | 09:18 PM
  #25
gsxranger's Avatar
Ok, I got my heads milled down the the max, .002 and the intake manifold fit on no problem.
Now, I can't believe I did this, but I did not label the rocker arm assemblies ( I did not disassemble them), and after searching for a half hour, can not identify which is right and which is left. It looks like it is important to put them on the correct side. Any way to tell them apart?
Old Nov 20, 2018 | 09:50 PM
  #26
mollusc's Avatar
"Fit each rocker shaft assembly, ensuring identification groove is uppermost and towards front of engine on RH side and towards rear of engine on LH side."
- 4.0 & 4.6 Litre V8 Engine Overhaul Manual (LRL0004ENG - 4th Ed), OVERHAUL p.3
I'm not sure if that helps you identify which side is which, or if it just helps you ensure that you've got them the correct way around.
Old Nov 20, 2018 | 10:03 PM
  #27
gsxranger's Avatar
Dang thanks! I just took the rocker cover off the driver's side, do you think the LH side means the US drivers side? If so I got lucky and got them correct, the notch is towards the back on the driver's side.
Old Nov 20, 2018 | 10:37 PM
  #28
gsxranger's Avatar
But, thinking about it a little more closely, they are in this sense interchangeable, if I mounted the one on the LH side to the RH side, the notch would be towards the front. The only way to do it wrong would place the pushrod ends obviously in the wrong position on the metal pad instead of the indentation on the rocker arms.
Old Nov 21, 2018 | 06:53 AM
  #29
mollusc's Avatar
"References to RH and LH banks of cylinders are taken viewing from the flywheel end of the engine."
So yes, LH side is the US driver's side.
This does not help you reinstall the rockers in their original positions, but it ensures that they're at least oriented correctly.
Old Nov 22, 2018 | 10:23 PM
  #30
Now would be a good time to look at your lifters...if the bottoms are coned, you may want to change them out.
twin6
Feb 23, 2017 09:02 AM
WaldoWilburforce
Jun 3, 2015 11:29 AM
NorCalDisco
Aug 24, 2014 01:01 PM
Effie1959
May 28, 2013 06:18 PM
AL518
Mar 5, 2013 11:41 AM
