Head stud kit. Best place to buy?
Old Sep 24, 2014 | 06:11 PM
knightmetro's Avatar
Default Head stud kit. Best place to buy?
Ok, I'd like to order these by the end of the day, but I want to make sure I'm getting the right ones and for the best price. Figure I'd drop this out there before I order.
I have a 04 Disco II 4.6 I'm rebuilding and need to bolt the heads back on soon.
What's the best ARP head stud kit to get, and where?
Thank you!
Old Sep 24, 2014 | 08:52 PM
acamato's Avatar
Lucky8.
Old Sep 24, 2014 | 08:55 PM
dr. mordo's Avatar
Yep, Lucky8 was the cheapest I found.
Be sure to read the directions and you might want to google torques, because people have experimented a bit with the studs to find the 'right' torque.
Old Sep 25, 2014 | 01:12 AM
That's what I thought. Putting in my order.
Thanks.
Old Sep 25, 2014 | 09:08 AM
drowssap's Avatar
that is a very good price if it is the ARP kit (157-4301) not the old kit (124-4003) which is half the price and made for metal head gaskets not composite gaskets.
Old Sep 25, 2014 | 09:21 AM
Alex_M's Avatar
From what I've heard, studs aren't really recommended unless you will be tearing the heads off semi regularly. Since they are harder then the head bolts they won't pull the threads down and lock in good, eventually they will back out and cause you to need head gaskets again. I would recommend just sticking with regular head bolts, there's no problem with them other than having to replace them every time you take your heads off which is anything but often.
Old Sep 25, 2014 | 09:32 AM
drowssap's Avatar
you might want to read up and decide for yourself:
2014 ARP Catalog
Old Sep 25, 2014 | 11:09 AM
RicketyTick's Avatar
Thanks.
From what I can find from poking around for a few minutes that's about the average price for the old buick set 124-4003 for metal gaskets.
The price for the correct set 157-4301 with the extra thread engagement for composite gaskets and 10 bolt heads is closer to $200.
Odd they don't put the part # in the item description. Maybe they carry both sets?
I'd ask!
Old Sep 25, 2014 | 11:16 AM
WNYErikDiscoII's Avatar
Former Sponsor
The ARP kit we are selling is for composite gaskets. We put them in all our own personal trucks with Elring gaskets as well as all customers trucks we rebuild here.
Old Sep 25, 2014 | 11:17 AM
Thanks.
That's a good price then. Do they ship in the ARP 157-4301 box?
