Headgaskets or what?
unfortunately, this is where i though you would end up.
the biggest PIA is you have to drop the oil-pan in order to get the front cover off.
crank bolt is the hardest part you need to break that free it is torqued to 200 psi.
fairly basic just a lot of bolts to pull and replace.
if you haven't done it before i suggest you lay all your gasket on to a piece of cardboard and spray with gasket cement.
this will leave an outline on the cardboard as you remove a bolt stick it into the cardboard, then you will know where to return them.
get the rave and study it (but it is incorrect) on the number of oil pan bolts there are actually two more than it tells you.
there are a few other tricks pm if you want them.
ps if you're going in there i would replace the oil pump and timing set while i was their.
Fenix
02-18-2015 10:42 AM
