Headgaskets or what?
Old Apr 4, 2014 | 04:13 PM
zeroone's Avatar
It isn't really. It's about as hard as removing the entire intake and plenum. Just replace anything in there parts wise that you find questionable. And remember where the long bolts go.. There are 2 different length bolts that hold the water pump and timing cover on the block.
Old Apr 5, 2014 | 05:22 AM
drowssap's Avatar
unfortunately, this is where i though you would end up.
the biggest PIA is you have to drop the oil-pan in order to get the front cover off.
crank bolt is the hardest part you need to break that free it is torqued to 200 psi.
fairly basic just a lot of bolts to pull and replace.
if you haven't done it before i suggest you lay all your gasket on to a piece of cardboard and spray with gasket cement.
this will leave an outline on the cardboard as you remove a bolt stick it into the cardboard, then you will know where to return them.
get the rave and study it (but it is incorrect) on the number of oil pan bolts there are actually two more than it tells you.
there are a few other tricks pm if you want them.
ps if you're going in there i would replace the oil pump and timing set while i was their.
Old Apr 5, 2014 | 09:06 AM
NWROVERS's Avatar
Sounds like my sunday is planed for me to be in the garage all day. What is the easiest way to get the bolt off the crank pulley. I heard a breaker bar and bumping the engine was a way to do it. I just dont want to buy the factory recomended tool for one job.
Old Apr 5, 2014 | 11:07 AM
drowssap's Avatar
i used an electric impact.
i think i jacked the body a little to get clearance without removing the radiator.
Old Apr 5, 2014 | 03:06 PM
zeroone's Avatar
Breaker bar and bumping the engine is the way to go. Try not to panic when it breaks loose. It will sound like you broke something. Lol
JerrodSteph
Feb 26, 2009 09:28 PM
malmberg
Feb 12, 2009 07:30 PM
ryanD2
Jan 24, 2009 07:31 AM
MK6000
Oct 1, 2008 10:37 PM
