headlight bulb replacement
Old Jan 15, 2010 | 04:36 PM
Classklown90's Avatar
Default headlight bulb replacement
Tonight while driving I noticed that my headlight bulb had gone out, with a 96 landrover do you just replace the bulb or the whole headlight itself? I know that with my blazer the entire headlight is replaced. If it is just a bulb what size do I need and how do I go about replacing it. It is a 96 discovery drivers side light thank you in advance
Old Jan 15, 2010 | 05:08 PM
yloDiscoII's Avatar
It's just the bulb.
Don't know the part number for the headlight, but any auto part store will have the booklet to tell you the right one, it's 3-pronged.
Just unplug the harness from the bulb, remove the rubber sleeve, twist the bulb out, and replace with a fresh bulb and reinstall everything reverse.
Old Jan 15, 2010 | 05:17 PM
hilltoppersx's Avatar
Rotate the three retaining clips to align with slots in headlight mounting plate. Then just pull the light assembly out.then get yourself a pair of 9003SU Silverstar ULTRAs
the bulb is a 9003
Old Jan 15, 2010 | 05:25 PM
okdiscoguy's Avatar
DO NOT TOUCH THE GLASS WITH YOUR FINGERS>>> it will burn out fast if you get oil from your skin on it.
Old Jan 15, 2010 | 05:29 PM
yloDiscoII's Avatar
Lightbulb
GOOD POINT. I ignored this once and burnt out a new set in less than 2 weeks
Old Jan 15, 2010 | 08:05 PM
Awesome thank you guys
AZRover
Jan 15, 2014 04:29 PM
jna97
Feb 21, 2013 12:56 PM
Classklown90
Aug 21, 2010 07:24 PM
nickm2k1
Oct 24, 2008 11:32 AM
mfryburg
Oct 19, 2008 10:38 AM
