Headlight Help!!!
Old Mar 28, 2011 | 07:49 PM
gavone1976's Avatar
Default Headlight Help!!!
Headlights are barely lit and they wont switch from high beam to low and the high beam light is lit on the dash.I just got a brand new battery and the alternator tested good.Any thoughts?
Old Mar 28, 2011 | 09:24 PM
unimoged's Avatar
Probably your high beam low beam switch inside the turn signal stalk has failed or is shorted.
Old Mar 28, 2011 | 09:38 PM
gavone1976's Avatar
CAn I take that out without removing the steering wheel?
Old Mar 31, 2011 | 05:14 PM
gavone1976's Avatar
I replaced the switch and I am still having the same problem.Any thoughts?
Old Mar 31, 2011 | 05:22 PM
Snafu / Disco Fries's Avatar
Any fuses blown at all? Check both under the dash AND under the hood at all of them. There are separate ones for right and left beams as well under there. Maybe pull the one under the hood for the high beams one at a time and go from there.
Old Mar 31, 2011 | 05:31 PM
gavone1976's Avatar
All the fuses are good,I pulled every fuse out and they are all good.
Old Mar 31, 2011 | 05:59 PM
jafir's Avatar
Since the lights are are "working" are dim, I'd check for a bad ground. Look in the electrical circuit diagrams in RAVE for the exact locations.
Old Mar 31, 2011 | 06:30 PM
ajmille's Avatar
does sound like a bad ground, pull the wire looms at the head lite, use electric spray to clean them, make sure no wires are broke. if this dosnt work cheak the relay, take it out and use another one thats in your truck, just make sure its the same, if that dost work it could be your switch.You could say screw it and bypass the O.E.M relays and get a heavy duty relay kit and wire them up right up to your batt. the kit is around $50.00, may be cheaper.
Old Mar 31, 2011 | 06:46 PM
coors's Avatar
You replaced the turn-signal/headlamp switch on the steering column? Can you verify the quality of the new switch? Is it a new or used switched?
If it's new and your still experiencing the same issues I would check for a sticky/faulty relay.
The lights worked fine before the battery change? Check to make sure the negative/positive battery terminal cables are securely fastened to the battery post.
Old Mar 31, 2011 | 09:10 PM
More interested in seeing what happens with the high fuses out. Would the lows be regular and the light off the dash.
