headliner cleaning
I had the famous "A" pillar leak and just got around to fixing it. Now there is a stain in that area of the headliner due to the dirty water leaking in. Anyone had success with any particular product/method of cleaning theirs?
[align=left] [/align]
...As for cleaning it, some sort of a VERY mild soapy solution sprayed on just one spot, use a shop vac to remove the solution, then spray just a small amount of water to rinse it off. Let it dry and see how it turns out before you try and clean the whole area. BE VERY careful a strong soap will ruin your headliner!
Leave you windows open and don't douse the cleaner on. Do it as light as possible. My buddy threw wet camping gear in the back of his truck and in the morning, his headliner has completely fallen down.
Turtle wax 'power out' foam carpet cleaner works great. In order to limit spot showing, spray some of it on a semi-wet rag and do the rest of the headliner.
CandiMan
Aug 12, 2012 10:41 AM
