Headliner queations
Old Jul 2, 2018 | 06:21 AM
zuke's Avatar
I just finished mine this weekend. It was my third time so I really wanted this one to come out good. I have the grey/black interior so I matched the original color.
Old Jul 2, 2018 | 10:22 AM
Sixpack577's Avatar
That looks really good.
Did you sand it smooth?
It doesn't look textured in the picture.
Old Jul 2, 2018 | 11:51 AM
zuke's Avatar
I scrubbed the hell out of it then took a bunch of old spray paint in various colors and put on a thick coat over everything. Then I took a random orbital sander with 120 grit pad and sanded it out. Then I coated the whole thing with black bedliner. Brand is important here beacause you want the splattery stuff with texture. I used this:
After that use 2 coats of your final color with a shorty 3/8" nap roller.
Old Jul 2, 2018 | 03:41 PM
Motorhead1's Avatar
you can also just use Killz primer, two coats brushed, then do two coats of Latex exterior enamel color of your choice.
Old Jul 2, 2018 | 06:00 PM
mln01's Avatar
In my opinion, painting is the way to go. The headliner will never again sag.
I did mine 8 1/2 years ago and I smile every time I think about it. No sanding was necessary; the pebble finish of the fiberglass shell is great.
Removing the headliner shell is tedious but not difficult. Once you have it out, pull off the sagging fabric. You'll find that it's not the factory adhesive that failed, it's the thin layer of foam in between the fabric and the fiberglass shell that breaks down.
Once you have the fabric and most of the old foam cleaned off (I used a stiff brush), use denatured alcohol to clean off the rest of the foam and the adhesive residue. Denatured alcohol works great.
Once the shell was clean, I primed it with Kilz, then rolled on two coats of a good exterior latex paint, using a brush in the corners. I took a piece of the old headliner fabric to The Home Depot and they matched the color very well. A pint was more than enough. I love the results.
Attached Thumbnails Headliner queations-photo260.jpg   Headliner queations-photo95.jpg   Headliner queations-photo583.jpg   Headliner queations-photo954.jpg
Old Jul 3, 2018 | 06:47 AM
zuke's Avatar
While you are there, shorten up the top chords on the cargo nets. They have little metal clips with teeth that grab the chord. Just pry out a bit and pull about 3'' of slack up and squeeze the clip down. Looks tons better.
Also be real gentle with those plastic posts that have the metal nut on them. They snap off very easily.
BrandonG83
Apr 30, 2015 02:47 PM
jalodge
Sep 22, 2013 12:12 PM
Ross Landiepanzer
Jan 7, 2013 04:55 PM
ATXDisco
Sep 21, 2010 09:37 PM
Aj6543
Sep 19, 2009 03:44 PM
