Headliner Re-Do
Old May 29, 2013 | 08:44 AM
agthird's Avatar
Redoing the headliner in fabric isnt much more expensive than painting it. It helps to have an extra pair of hands when laying the fabric down just remember to use the right glue. The fabric serves as an extra layer of insulation from noise and heat. 2 cents.
Old May 29, 2013 | 01:55 PM
eitydeuce's Avatar
That was one of the main reasons why I decided to insulate the roof. I didn't want it to echo even more because of not having the fabric their to tone the noise down.
Old May 29, 2013 | 02:14 PM
04duxlr's Avatar
I'm going to upholster mine. I like the look of the black fabric. I have a grey truck with black carpet, dark seats and the grey pillar trim and handles so it should look pretty nice. Should hide any grime the kids manage to smear on it too. I'll put extra effort into making sure that the leakage through the sunroofs is minimized and that it all gets into the drains so that should make it last a while.
Old May 30, 2013 | 06:10 AM
hilltoppersx's Avatar
to play devils advocate the original foam between the material and the actual fiberglass headliner is only one eighth of an inch thick which is why it fails In the first place. so I don't think adhering a piece of suede directly to the headliner would prevent anything. If you want your truck be cooler paint the roof white like a series truck. if you wanted to be quieter then use Dynamat above the headliner
Old May 31, 2013 | 02:52 AM
dpaller's Avatar
I did mine in a charcoal grey ultra suede. Buddy works for a custom shop and ordered me the proper material with the foam backing. it was exactly wide enough to fit our huge headliners width wise. He brought his glue spray gun and made it look easy.
I love the way it looks.........and feels.
Old May 31, 2013 | 06:45 AM
jhill15's Avatar
That's sounds sweet, can you post some pics of your liner? If I re do mine again I'm thinking about going back to a fabric and a leather type material would be nice.
Old May 31, 2013 | 07:11 AM
drowssap's Avatar
one thing to remember it is the foam that gives out not the headliner, so if you redo it using a foam back material it will happen again.
Old May 31, 2013 | 10:49 AM
dpaller's Avatar
i will worry about that again in 13 years, the first one made it that long. no way I would rock a painted one because I was worried the foam was going to give.
Old May 31, 2013 | 10:50 AM
dpaller's Avatar
yeah for sure
Old May 31, 2013 | 04:02 PM
SuperSport's Avatar
+1 Agreed! If I get 13 more years (in my case 10) out of any of my repairs, I consider myself lucky.
