Headliner: tear down for new fabric
#21
Here is a good thread for anyone giving it a try. I've done two. Use a wire brush to remove foam. Apply glue to both fiberboard and material. Allow it to set for a couple of minutes. Start from the middle and work outwards. Take your time. Leave enough overlap to glue the excess to the other side of the board which helps keep wind from tearing the foam away from the cloth.
https://landroverforums.com/forum/di...76/#post191929
#22
I second the painting route. Really easy to do and looks good enough. Just rip off the fabric, and use a wire brush to remove the left over foam. Its a messy job so be prepared to clean up. I wiped it down with rubbing alki as best i could before painting. Went to home depot with a plastic trim piece and they matched me a gallon of interior paint (might have been exterior, can't remember) Two coats was all it needed.
Consider doing some insulation while the head liner is out.. again, super easy.
Ross Landiepanzer
01-07-2013 04:55 PM
