Heads: disco 1 and 2 interchangable
I am looking for some heads to build up for my disco 2. Can I get some from a disco 1?
I read a couple things that the SAI hole is the difference?? Can I just ditch the SAI?
Asking since there are a lot more cheap heads to start with from disco1s out there.
Or I should ask, is there some particular year that they were the best?
Is there a performance head I can buy somewhere?
This could be a seperate thread, but, do I need SAI? I know what it does is help warm up the cats when cold. Does nothing for performance or longevity that I can see. Just more weight and things to break, no? Can I remove it alltogether? Would I get a check engine light if i did? On previous cars I have blocked off head-clogging EGR valves, but at least SAI doesn't seem to have any specifically bad features.
yea. I figured a light would go on. I could remove the system AND cut the wire to the check engine light! 2 problems solved!
Curious though: how would it know the system isn't working? Think it's sensing that there should be a leaner mixture at the 02 sensors when it blows? Resistance from the fan?
I'd rather repurpose the SAI to be an on-demand electric supercharger.
Ok, i've gotten a bit silly here. But really though
tdorland
05-24-2013 11:32 AM
JBEGIN
06-27-2009 12:38 PM
