Heated Seats and CDL Disco2
Old Feb 20, 2016 | 04:41 PM
chubbs878's Avatar
Originally Posted by chubbs878
The heat in the seat mysteriously began working while I was driving last night. Typical. On the CDL, I pulled the housing from the donor, along with switches/sensors but the main shaft with gears would not come out. Maybe if I pulled the rear output flange it will slide out forwards. In the RaVE the gear sets and output shaft look identical. Is it possible to use the modified housing with my current transfer case output shaft and diff component? I read somewhere that josh salas said it was better to do it this way rather than swap the whole shaft because of the trouble re-setting the detent ball/spring.
I came across this in an old thread. He also used only the housing and not the housing/gear-set combo...
Originally Posted by Keanan
Why did you take it apart so much? You don't have to pull the gear set out to replace the front cone.
Is it required that the gears be replaced also? I just swapped the front cone on mine and it has been fine for the last 10,000 miles.
turbodave
Mar 29, 2019 07:22 AM
weeped
Feb 13, 2016 01:16 PM
booper169
Nov 9, 2010 09:10 AM
bigugly82
Jan 7, 2007 10:20 PM
sydneysport
Oct 1, 2006 09:18 PM
