Heater
Old Oct 9, 2006 | 06:30 PM
elrey10's Avatar
Default Heater
My 2000 Disco has a problem with the heat. I have it on high and only cold air comes out. What could be the problem? Is it possible that it could be caused by a fuse?
Old Oct 9, 2006 | 07:15 PM
jskrebs's Avatar
Default RE: Heater
On ours the heater core was blocked by stop leak.
Can you go into manual and force air out the bottom vents? If so that is good, you can them pull the glove box and see if the heater hoses are hot, if they are not the core or hoses are blocked, if they are hot the temp mixing servo could be faulty.
Old Oct 9, 2006 | 09:23 PM
Default RE: Heater
Have you checked your coolant lately, have you been having to add coolant?
Could be just a low coolant problem, but that in turn could be either a coolant leak or head gaskets.
Mike
ls1morethanyou
Jan 12, 2017 10:21 AM
tonygallagher
Jun 17, 2006 08:22 PM
jomeheretu11
Nov 1, 2005 05:13 PM
philipm7
Aug 27, 2005 10:12 PM
ddugan
Feb 20, 2005 02:27 AM
