heater core o-rings help
Old Oct 25, 2014 | 11:04 AM
dirtlord's Avatar
Default heater core o-rings help
ok i removed the glove box and got the clamps off now i can not get the lines off the core. did i for get to remove somthing or are they just a pain to get off?
Old Oct 27, 2014 | 08:07 AM
dirtlord's Avatar
anyone?
Old Oct 27, 2014 | 08:30 PM
Fast951's Avatar
My understanding is that after you remove the squeeze clamps the pipes will come out, but the o-rings could be holding things together tightly so you may have to work the pipes back and forth a bit.
Why are you removing the pipes? Two most common reasons are (1) the engine side of the pipes are damaged and no longer make a good seal to the double hose, or (2) the o-rings are leaking. Leaking o-rings are pretty rare. Sometimes, it appears o-rings are leaking but what actually happens is coolant runs down from the double hose past the double grommet and thru the firewall because of reason (1) above.
If you suspect that is happening go ahead and replace the OEM squeeze clamps on the engine side with a couple of good worm gear hose clamps. If you really crank them down you can make even the most damaged pipes on the engine side seal.
Tayrover
Nov 30, 2011 10:37 AM
sdbimmer
Oct 21, 2011 06:12 PM
Spencerfitch
Sep 28, 2010 07:49 AM
JAC
Nov 16, 2009 02:50 PM
wizardmagu
Sep 21, 2008 04:45 AM
