hedman headers/ flowmaster muffler installed
Old Aug 15, 2015 | 04:43 PM
  #41
jessezipper's Avatar
thanks to alex_m i made my intake today after ordering all the parts...
i can really feel a little more power now !!
Old Aug 16, 2015 | 11:01 AM
  #42
jfall's Avatar
You need Bosch sensors.
As long as you got a sensor before the cat and one behind it as before
you should be good to go.
The cat will need to scrub close to what the spec cats had done in the past.
you get an "A" on your report card for being an intelligent hardworking adventuresome soul and kudos to ya.
Here is my old writeup on Cats and O2's on a D1.
May be helpful as nothing has changed with O2's
http://jeffreyfall.com/landrover
Old Aug 16, 2015 | 02:01 PM
  #43
i plan on doing something similar to my range rover classic
Old Aug 17, 2015 | 12:20 AM
  #44
chubbs878's Avatar
T
He deleted out the catalytic converters. That's what the whole post is about. Nice work on the intake and exhaust! Please update in the future if you start getting codes related to the O2 sensors or otherwise
Old Aug 17, 2015 | 12:47 AM
  #45
chubbs878's Avatar
Lightbulb
You can go to ACE hardware and find some material for about $3 to filter your cabin air. AB sells it for $15 or $20 before shipping but I like to stimulate economic growth in my own area and therefore try to buy as much as I can locally before having to order from elsewhere especially if I'm saving $20! You will have to cut it into 2-inch strips to fit but it only takes a few minutes and you will feel better having utilized an original factory function of the vehicle however minuscule it may be
Old Aug 17, 2015 | 08:31 AM
  #46
Charlie_V's Avatar
Chubbs have you done any kind of write up on the cabin air hack?
Old Aug 17, 2015 | 10:01 AM
  #47
chubbs878's Avatar
no, I sure didn't. I didn't feel it was worth the topic but if you are interested i can probably do a little something in the next day or 2
Old Aug 17, 2015 | 10:07 AM
  #48
Charlie_V's Avatar
Definitely interested. My foam disintegrated long ago and the result is a dusty cabin and, worse, clogged drain nipples.
Old Aug 17, 2015 | 10:10 AM
  #49
chubbs878's Avatar
OK no problem. i will try to do it this evening then
Old Aug 17, 2015 | 10:15 AM
  #50
Charlie_V's Avatar
I bought OEM foam once... it dried up and fell apart almost instantly... and got sucked into the system! I never could get it to stay properly. In fact, when I first started paying attention to my rover, the only foam I saw was under the plastic retainers... I thought it was for vibration!
Didn't mean to give you a job but if you're willing I'll have the mod done almost immediately and nominate you to the mod list. My nominations have vaulted Alex to well-deserved mod stardom!
