Hella 4000 Wiring
Old Jun 16, 2018 | 08:04 AM
abran's Avatar
Originally Posted by Twix
Like I said, 10 would work, but if it gets hot enough it will cook the insulation. 10ga is rated for 30A at 25C, the engine compartment would be well hotter than that. The derating would end up at around 20A. Now, because these lights will likely not be on all the time, you might be ok with 10ga.
For comparison, my 240w light bar came with 10ga wire. That wire still gets hot if I have the bar on for long periods of time. 240w @ 12v is 20A. 10ga is rated for 30A. 400w @12v is 33.333A. It's right on the cusp. 8ga is rated for 45A, which is overkill, but would definitely give room for running the lights for long periods in hot temps
thank you for the breakdown.
Old Jun 17, 2018 | 08:00 PM
jmayzer's Avatar
This is the wire that I'm thinking: https://www.lowes.com/pd/Southwire-1...e-Foot/3129527
Thoughts? How much of it should I get?
Old Jun 18, 2018 | 12:28 AM
JUKE179r's Avatar
IMHO go with tinned marine grade cables or wiring for soldering your connections. Marine grade wiring has better resistance to corrosion over time.
I prefer the Ancor brand. You can get it from a boat company or online.
windsoreight
Jun 14, 2014 09:03 AM
eitydeuce
Sep 17, 2013 08:09 PM
angasreid
Dec 9, 2010 02:45 PM
mpparamedic
Jul 24, 2010 06:55 PM
Dan_da_LR3_H2_man
Nov 10, 2008 12:31 AM
