Hello, Im new....my Disco needs your help
Old Sep 5, 2009 | 07:42 PM
www.mechanicdoctor.com
Old Sep 5, 2009 | 08:04 PM
instg8r's Avatar
i just checked the codes, they dont really say much other then there was a misfire
Old Sep 5, 2009 | 10:10 PM
SDinDS's Avatar
Originally Posted by instg8r
ok i scaned it, the codes are
p1316
p1313
p0307
p0000
I left the scaner pluged and i went for a drive. what i did notice is that the speed that the scanner was reading was way off. at times reading 180 kph when im doing 50kph.
i did some poking around on the net and i noticed that some guys with my similar issue had bad VSS.
what do you guys think?
P0307 Misfire on cylinder 7
P1313 Misfire Catalyst Damage Fault Bank A
P1316 Misfire Excessive Emissions Fault
Old Sep 5, 2009 | 11:08 PM
instg8r's Avatar
Is there a way to diagnose the VSS? multi meter?
Old Sep 6, 2009 | 10:08 AM
SDinDS's Avatar
Yes, you can check the VSS thru your cruise control ECU. Find a good ground then back-probe on the ECU wiring harness on terminal 11 (should be a yellow wire) Spin the rear tire tire (or drive it) at 3mph. The voltage should be 2.5volts, but may vary between 0 and 5 volts.
Eric
Old Sep 6, 2009 | 11:54 AM
instg8r's Avatar
great, thanks i will try that tomarow
Old Sep 9, 2009 | 09:05 AM
instg8r's Avatar
where is the VSS located?
discoweb.org is down
Old Sep 9, 2009 | 04:14 PM
It is on the bottom of the trans, near the output shaft if I remember correctly.
You will need a allen head socket and 12" on extensions to reach it.
No sure what size allen.
Old Sep 10, 2009 | 11:23 PM
instg8r's Avatar
it definatly was the VSS. i replaced it and it cured the problem.
she drives great now!
sweet!!
Old Sep 11, 2009 | 05:39 PM
sweet!!
WOW!! I actually got one right? lol
Thank you for posting what the fix was.
munchkin#1
Jun 30, 2011 04:10 AM
OEWheelsLLC
Tires
Aug 26, 2010 12:38 PM
L R Novice
Sep 8, 2009 09:28 AM
ek5usmc
Off Topic
Nov 9, 2008 01:52 PM
