Hello, Im new....my Disco needs your help
ok i scaned it, the codes are
p1316
p1313
p0307
p0000
I left the scaner pluged and i went for a drive. what i did notice is that the speed that the scanner was reading was way off. at times reading 180 kph when im doing 50kph.
i did some poking around on the net and i noticed that some guys with my similar issue had bad VSS.
what do you guys think?
p1316
p1313
p0307
p0000
P1313 Misfire Catalyst Damage Fault Bank A
P1316 Misfire Excessive Emissions Fault
Yes, you can check the VSS thru your cruise control ECU. Find a good ground then back-probe on the ECU wiring harness on terminal 11 (should be a yellow wire) Spin the rear tire tire (or drive it) at 3mph. The voltage should be 2.5volts, but may vary between 0 and 5 volts.
Eric
Eric
Thank you for posting what the fix was.
maxman
Jan 28, 2015 08:08 PM
