Help with ABS Amigos box data
Here's what I get:
-----ABS Amigo Box V1 RSW Solutions LLC Copyright 2010-----
|* The information provided is without warranty of any kind.*|
|* IN NO EVENT SHALL RSW Solutions BE LIABLE FOR ANY LOSS OR*|
|* INJURY OR DAMAGES resulting from or connected to use of *|
|* this Information or Product. YOU HEREBY WAIVE ANY AND ALL*|
|* CLAIMS AGAINST RSW Solutions ARISING OUT OF YOUR USE OF *|
|* THIS INFORMATION OR PRODUCT. *|
1.--Current Faults---->
Active Faults:
None
Logged Faults:
None
<-END Faults
..--Previous Faults--->
Active Faults:
None
Logged Faults:
044:Front Right sensor output low
Front Right Sensor Bad Output
Front Left Sensor Bad Output
114:Shuttle Valve Electric Failure
<-END Faults
Active Faults:
None
Logged Faults:
015:Pump fail pump running when not On
045:Rear Left sensor output low
Rear Left Sensor Bad Output
<-END Faults
Active Faults:
None
Logged Faults:
None
<-END Faults
Active Faults:
None
Logged Faults:
<-END Faults
Active Faults:
None
Logged Faults:
<-END Faults
Ok - after plugging the ABS Amigo Box and getting the above txt file, which lists no faults, I went and drove the car around for a while and no lights have come back on? I slammed on the brakes, turn on hill assist, did everything I could but all three lights remain off. There's just no way I'm this lucky. I bought the LR a couple of weeks ago and the lights were always on although the owner had documents of having all of the breaks worked on within the last year. Is it possible the lights just needed to be reset????
