help asap
Old Mar 21, 2013 | 08:14 PM
durry707's Avatar
8th Gear
Throttle cables only go one way or they'd cross each other never moved adjustments. Iacv never came off plenum. I drained coolant on vehicle due to movin heater hoses didnt want to chance coolant getting into plenum got all air bubble out of system seemed to help. But like said backed out to let sit while went to lunch came back started just loped. There are tabs on the lower intake te the upper plenum sits on I cleaned around them to get a good fit when putting back together I made sure it sat flush on the lower being that ive never done that much to a land rover was a 1st timer job on one. I took my time in checkin it due to that fact. I do get a humming out of the Iacv. Don't know if tht is anything to do with it.
Old Mar 21, 2013 | 08:19 PM
durry707's Avatar
8th Gear
Aarongregor bout 30 minutes from Harrisburg pa. Don't worry bout being a jerk I'm open to anything but I have checked that because I feel it's something small but I think I'm over thinking it. My boss is gone for the week and he gets more in depth with diagnosing so my back bone is gone have nothing to turn to.
Old Mar 22, 2013 | 12:54 AM
Robert Booth's Avatar
I had all of the same codes and same symptoms, replaced MAF, replaced TPS, cleaned IACV , didnt solve.
turns out my truck was suffering from a rushed engine swap with a Range Rover 4.6 prior to me taking ownership.
Interestingly enough, the problem only developed AFTER i drove the truck 900 miles home to Seattle from LA after buying it
Jahn jumped onto this forum to explain in greater detail what he did when he fixed it. I was at a loss because nothing like this was documented in the RAVE.
https://landroverforums.com/forum/di...5-45643/page2/
The reason that i'm posting here and reposting the link is that you mention valve cover gaskets, a similar problem area to that which i encountered.
Old Mar 22, 2013 | 02:49 PM
durry707's Avatar
8th Gear
well gentelman thank you for all the suggestions and guidance but after hrs of checking double checking triple checking and one tps and iacv vehicle is still with issues. nothing i have done so far to the rover has changed nor fixed these issues i have pulled the ac compresser back checked all my work over no wires missing mis routed nor off of any sensor or hoses. this vehicle has tested my patients and my bosses time im out of ideas. thanks again vehicle will stay for the big boss to check.
Old Mar 22, 2013 | 02:52 PM
durry707's Avatar
8th Gear
robert booth yea valve covers were replaced here not a horrible job took my time being never been that far in on a land rover or had much experience with them. but turned out the vehicle had other plans and ****ED ME HARD!!!! wasted over two days and $$$$$$$
Old Mar 26, 2013 | 09:05 PM
durry707's Avatar
8th Gear
Well problem solved don't know how it happened throttle cables pulled tight causing to idle high. I never messed with the cables I don't understand y they pulled tight. Adjusted vehicle ran fine thank you guys for all the help. Feel like a dumb *** have a good week everyone
Urgeasaurus
Dec 12, 2010 03:16 PM
Brokenrover
Dec 14, 2007 08:27 AM
chris79
Nov 22, 2007 09:40 AM
Brad S1
Jun 28, 2006 03:25 PM
TATZOO
Aug 28, 2005 10:16 PM
