Help with bottom engine bolt broken.
Old Jun 8, 2020 | 07:20 PM
landroverdude's Avatar
Default Help with bottom engine bolt broken.
Hey guys I have a large problem, I was trying to tighten this bolt up because it was leaking and it snapped off around it and so question 1 what the heck is this bolt? And then 2
what the heck am I supposed to do now? Help.
Old Jun 8, 2020 | 07:30 PM
Ah alrighty I guess I just found out it's the oil cooler plug? Either way if so how the heck am I supposed to fix this lol.
Old Jun 8, 2020 | 07:44 PM
XRAD's Avatar
that really sucks! options:
1) some kind of metal epoxy and a prayer, and hope it does not blow out on the highway
2) have broken part welded back in
3) have the whole area welded with a new bung machined for that plug.
not sure if you can weld this in place upside down because you need a mig welder and a lot of heat.
It was leaking because of old O ring, and maybe because of a hidden crack, which you just found....
Old Jun 8, 2020 | 07:52 PM
Yeah I was thinking about welding but now that I think about it my engine has high mileage at about 135,000 so honestly I could just replace the whole front timing cover probably needs it anyway, if I wanted to go a more pricey route but at least I know that would work
Old Jun 8, 2020 | 07:53 PM
Because that's that screw on the bottom right there.
Old Jun 8, 2020 | 08:02 PM
XRAD's Avatar
yep, that is the best way , and get some oil pump gears too.....
Best4x4's Avatar
Looks like new front cover time. You could get one from a junk yard and save some $$$ as they usually go for around 400-500.00 new.
Old Jun 8, 2020 | 08:32 PM
Red5's Avatar
I vote for a new (or good used) front cover.
Unrelated, but what’s up with that oil filter? How long has that thing been there?
Old Jun 8, 2020 | 08:35 PM
Best4x4's Avatar
LOL I was thinking the same thing when I saw that oil filter!
Old Jun 8, 2020 | 11:08 PM
Well when I sprayed up under there to clean the engine with the power washer a whole lot of it came off today but either way yeah it's due in for a new one anyway lol.
Lisa Bunch
Apr 2, 2019 10:08 PM
adolfojbonilla
Jun 10, 2017 09:39 PM
Noah Woodcock
May 11, 2017 07:11 AM
DuoRover
Dec 4, 2016 07:23 PM
etsZac
Jan 5, 2014 04:05 PM
