Help changing Trans Case , transmisison, and differentials fluid.
Old Jul 22, 2009 | 07:22 AM
On that golden brown tranny fluid, I would drain and refill once, run it in gear for a minute or so and then drop the pan, change the filter and again add new fluid. By doing this, you will get a lot more of that old fluid out of the system, other wise your tranny is still running on bad ATF and will be short lived.
Old Jul 22, 2009 | 10:30 AM
josemex's Avatar
Mike so I should drain, refill with new atf fluid runn it for a little bit and then drain and change the filter? what pump are you guys using??
Old Jul 22, 2009 | 11:09 AM
lipadj46's Avatar
Yes change the fluid first and run for a while. This will dilute the bad oil from the gears with good oil. Then drain and change the filter, good thing ATF oil is cheap.
You can buy a cheap hand pump from any of the automotive stores. Harbor Freight is probably your cheapest. Don't pay over $15 for one.
BFox15
Aug 3, 2011 06:47 PM
GARovee
Aug 22, 2010 09:57 AM
snafu
Sep 10, 2007 09:01 AM
merleti
Freelander
Aug 28, 2007 05:24 PM
topgear
Jun 18, 2005 12:29 AM
