Help with Collateral Damage
Old Dec 11, 2010 | 09:03 PM
pennohawk's Avatar
Default Help with Collateral Damage
So I finally tackled my plugs/wires replacement on my 04 Disco, the space is tight, it was tougher than I thought it was going to be.
While lying across the engine, I broke one of the connectors coming out of my intake plenum (pic below), described in RAVE as "Rocker cover breather hose connection". I am having trouble finding any details on this connector, is it threaded, is there a common replacement for it or LR specific? I was hoping to get a little more info before trying to remove the part that is stuck in the plenum.
Any help is much appreciated, Thanks!
Old Dec 12, 2010 | 03:45 AM
lipadj46's Avatar
That would be a PCV valve in any other vehicle, in ours it is just a threaded connector. Your best bet is the dealer.
Old Dec 13, 2010 | 10:38 AM
pennohawk's Avatar
Default Breather hose connection
Holy Crap!! The dealer wants $91.45 for this little plastic connector! Has anyone found a replacement for this little guy anywhere other than the dealer? I found a similar connector at my local auto parts store, it was metal, had the same 1/4" thread, but the hose barb had a smaller ID.
After closer inspection, it looks like the precious owner epoxied this connector back together (likely to save the 90 bucks), which explains why it broke with such a small amount of pressure.
Old Dec 13, 2010 | 10:49 AM
jhewitt1111's Avatar
I had the exact same problem. I went to auto zone bought a tool to thread it and put in a new threaded nipple that fit. about $20.00 with the drill bit to thread it. It has worked fine since. I asked the same question a while back and no one told me it would adversly affect the engine, so I went with it.
Old Dec 13, 2010 | 11:23 AM
jkid's Avatar
I seem to remember breaking mine a few years back, probably when I was doing the plugs. I went to Lowe's or something and bought a brass hose fitting in the plumbing department, it's like a 2 dollar fix.
Old Dec 13, 2010 | 11:34 AM
agthird's Avatar
x2 on brass npt I think got it at pepboys the threads were a little different but it was going on regardless(lol) I used some teflon tape..I did the exact same thing changing the wires..
Old Dec 13, 2010 | 01:05 PM
mln01's Avatar
Been there, done that a year ago. The Home Depot. Brass. Perfect fit and less than $5.
Old Dec 13, 2010 | 01:17 PM
pennohawk's Avatar
Thanks guys, I knew that not a single person on this board would pay a dealer 90 bucks for this part! I am on my way to Home Depot on my lunch break.
BC_LR3
May 6, 2007 03:37 AM
BC_LR3
Off Topic
Apr 23, 2007 03:44 PM
s4lex
Feb 11, 2007 02:40 PM
asmcmillin
May 7, 2005 11:19 PM
