HELP! (Cruise Control)
Old Aug 30, 2006 | 02:26 AM
97DISCOIDAHO's Avatar
Default RE: HELP! (Cruise Control)
Yes, that is normal. I also can hear the relay click in park but not in drive. It was the same before and after replacing the ECU.
Old Aug 30, 2006 | 09:16 AM
madas's Avatar
4wd High
So, just to confirm.
If you are already in drive, and then decide to master arm your cruise control, it won't work? before every trip I need to decide whether or not to arm the cruise control? is there any reason I cannot just leave it armed all the time?
Many thanks
Old Aug 30, 2006 | 11:51 AM
Yeah I know... it really threw me for a loop as well. Mine is the same... the relay won't click when the car is in drive. I can tell you the cruise in my Disco works just fine... doesn't matter if the cruise is off before I put in in drive. I can turn the cruise switch on after starting to drive and it works.
Just guessing here but I think it has something to do with a speed sensor that won't let you use the cruise control till you hit 30 mph (everyone says 35 but mine works at 30). Once you hit that speed I'll betcha you'll hear the relay when you switch it on and off.
Old Aug 30, 2006 | 11:54 AM
I almost forgot... don't miss that eBay auction... it closes tomorrow. (item number 330021555632) I was going to bid on it but ended up finding one at a salvage yard. That will save you a ton of money... atlanticbritish.com wants $219.99 and I'm sure the stealer is even more.
Old Aug 30, 2006 | 12:22 PM
madas's Avatar
4wd High
but I think my relay is working, at least it works fine in park!
Evan5291
Nov 21, 2017 07:59 AM
southfloridadiscoII
Jun 28, 2009 11:03 PM
Simone1
Freelander
Nov 18, 2008 05:11 PM
Phototone
Jun 14, 2008 08:20 AM
sgrol
Oct 19, 2005 12:49 AM
