HELP! D1 CDL install in a D2
Old Jun 13, 2010 | 02:43 PM
hilltoppersx's Avatar
PM Sent. Thanks NiteTrain. Looking forward to my slipless future.
Old Jun 13, 2010 | 05:02 PM
NiteTrain's Avatar
just got back from the lake..sent ya the file..hope it helps..let me know if you have any other questions
Old Jun 14, 2010 | 10:03 PM
Urban Panzer's Avatar
Originally Posted by NiteTrain
small bend, I put the linkage in a vise and hit it with a 5 lbs sledge hammer...no heat. Also, be aware the D1 linkage has 8mm holes and the tab on the transfer case is a 6mm hole...I had to order some bushings from mcmaster-carr.
The major PITA part is just getting in there and then getting everything back together..you have to do this no matter if you use the '04 linkage or the D1 linkage...using a D1 linkage and buying those .50 cent bushings saved me @ $365 over using a '04 linkage....well worth the savings IMO.
Exactly what I have done, twice now on 2 diff cars, a manual and an auto. REF the bushings, if you have a "hobby" type electric tool, which is quite small, you can get that in there and "open" up the transfer case lever hole with a small grinding stone.
Old Jun 15, 2010 | 12:21 PM
no matter what you have to dill the hole open? the plate from the D1 cannot be put in its place? i thought it might just bolt into place. im still waiting for it to arrive so maybe i'm completely wrong.
Old Jun 15, 2010 | 02:05 PM
NiteTrain's Avatar
thats a good question..can you just use the D1 cover plate?...I dunno, I used a dremel to cut out a square in mine DII cover plate so the shifter could fit.
Old Jun 17, 2010 | 12:10 PM
i will find out. should have the package today or tomorrow with the plate. the less cutting and **** i have to do the quicker i can get it done. then i can concentrate on other things.. like hub i need to replace.
Old Jun 17, 2010 | 10:01 PM
Jordanmd88's Avatar
Man Just finished (literally just came inside) my D1 CDL install in my D2... I have to cut the trans. tunnel plate tomorrow, then I hope to do some good off roading this weekend in TN...
Old Jun 18, 2010 | 06:28 AM
it was good times?
Old Jun 18, 2010 | 06:54 AM
Jordanmd88's Avatar
it was good times?
Sure it was good times.. Working on a Rover is always Good times
Old Jun 18, 2010 | 08:52 AM
can't wait.
