HELP! D1 CDL install in a D2
just got back from the lake..sent ya the file..hope it helps..let me know if you have any other questions
small bend, I put the linkage in a vise and hit it with a 5 lbs sledge hammer...no heat. Also, be aware the D1 linkage has 8mm holes and the tab on the transfer case is a 6mm hole...I had to order some bushings from mcmaster-carr.
The major PITA part is just getting in there and then getting everything back together..you have to do this no matter if you use the '04 linkage or the D1 linkage...using a D1 linkage and buying those .50 cent bushings saved me @ $365 over using a '04 linkage....well worth the savings IMO.
no matter what you have to dill the hole open? the plate from the D1 cannot be put in its place? i thought it might just bolt into place. im still waiting for it to arrive so maybe i'm completely wrong.
thats a good question..can you just use the D1 cover plate?...I dunno, I used a dremel to cut out a square in mine DII cover plate so the shifter could fit.
i will find out. should have the package today or tomorrow with the plate. the less cutting and **** i have to do the quicker i can get it done. then i can concentrate on other things.. like hub i need to replace.
it was good times?
