Help!!! Did I overfill T case?
Old Dec 8, 2012 | 09:30 AM
  #21
Bkreutz's Avatar
Originally Posted by lr2001silver
3.4 pints = 2.04 quarts (U.S. fluid)
So no body has to search
2 pints = 1 quart, so 1.7 quarts. Volume Conversion
(but I never measure, I just put it in untill it runs out)
Old Dec 8, 2012 | 09:37 AM
  #22
Open fill hole with 1/2 inch ratchet or breaker bar. Fill until it oozes out. Replace fill plug. Check for leaks. One guy drove half way across Montanna on a trip from the West Coast, and the drain plug came out enroute. That was expensive.
An "imperial" pint is 568 ml, the US is 473 ml. But math aside, the dang thing needs all the 85W140 it will hold.
Old Dec 8, 2012 | 09:52 AM
  #23
MC04DII's Avatar
So after looking at Rave's (should have done first) it looks like I filled it through the optional oil temp switch hole (item #12 on page 41-4) This was apparently an option up through 2002, but the hole for it was still there in 03-04 models as well. I will be degreasing the t-case and checking for leaks. Crossing fingers.
Old Dec 8, 2012 | 11:16 AM
  #24
DiscoRover007's Avatar
I think you'll be fine.
Old Dec 8, 2012 | 01:55 PM
  #25
MC04DII's Avatar
So far so good after driving around today. Got the guard dogs on and love em. Now just needs a lift and new front driveshaft.
Old Dec 8, 2012 | 02:29 PM
  #26
94svt50's Avatar
your fine I did the same thing. Its easy to miss the fill hole hiding on the back side of the transfer case. I realized something was wrong after starting on the third quart so, I caught it before driving anywhere.
Old Dec 8, 2012 | 02:41 PM
  #27
lr2001silver's Avatar
Banned
I am glad no damage!!! I can help you with the drive shaft get me your number and we can talk!
Old Dec 8, 2012 | 03:32 PM
  #28
jfall's Avatar
You're fine.
The fill hole can't be missed.
A 1/2 " drive removes it.
Meaning - the square extension itself.
You'll find the fill hole by tracing the emergency brake cable.
The EB cable interferes with removing the 1/2" plug.
So, that's how you know you have it correct.
And, you'll be fighting the ebrake cable the whole time.
As long as the fluid is up to that fill plug - like all have said - then you'll be just fine.
Old Dec 8, 2012 | 08:24 PM
  #29
Colorado David's Avatar
Originally Posted by jfall
. . .And, you'll be fighting the ebrake cable the whole time.
Boy, is that ever the truth.
Walko327
Mar 28, 2013 08:43 AM
sloppyjoe
May 15, 2011 02:29 PM
oysterhead
Oct 4, 2009 09:52 PM
ljdiscovery
Jul 2, 2009 02:04 PM
handsome rob
Feb 15, 2009 11:54 PM
