Help. DII o-ring size for PAS cooling line?
Hopefully someone recently messed with this and can help me out.
On top of the steering box I have a leak where the cooling line connects.
I been thru rave a few times but cannot find a part number, it only says "replace o-rings".
??Is there more than one o-ring on the pipe??
??anyone know a part# or size??
I bought a multi pack with no luck
even tried a new buick one I had for my old buick,,,,no luck
It was close, but still small leak.
Thanks again, wanna get this fixed before my wifes arms get any bigger.
Only one o-ring on the end of the pipe.
I've had no issues using metric o-rings from an assortment pack. The two lines are different sizes - one may be 5mm, the other 6mm? I just can't remember. I suppose if the cross section diameter is too big, that would give you issues.
If you have a pair of calipers (they can be had for cheap), then measure the spot in the pipe where the o-rings rides. IIRC o-ring sizes are the inner diameter, not the outer.
Be sure to lube up the o-ring with some p/s fluid, petroleum jelly (this is what I prefer to use), etc. in the hopes of not binding/pinching/damaging the o-ring.
bcolins
12-13-2023 10:47 AM
