Help. DII o-ring size for PAS cooling line?
Old Sep 21, 2012 | 08:56 AM
innzane's Avatar
Default Help. DII o-ring size for PAS cooling line?
Hopefully someone recently messed with this and can help me out.
On top of the steering box I have a leak where the cooling line connects.
I been thru rave a few times but cannot find a part number, it only says "replace o-rings".
??Is there more than one o-ring on the pipe??
??anyone know a part# or size??
I bought a multi pack with no luck
even tried a new buick one I had for my old buick,,,,no luck
It was close, but still small leak.
Thanks again, wanna get this fixed before my wifes arms get any bigger.
Old Sep 21, 2012 | 10:25 AM
Your only place to go would be the dealer and they may have to order them.
Old Sep 21, 2012 | 05:15 PM
Banzai Jimmy's Avatar
Only one o-ring on the end of the pipe.
I've had no issues using metric o-rings from an assortment pack. The two lines are different sizes - one may be 5mm, the other 6mm? I just can't remember. I suppose if the cross section diameter is too big, that would give you issues.
If you have a pair of calipers (they can be had for cheap), then measure the spot in the pipe where the o-rings rides. IIRC o-ring sizes are the inner diameter, not the outer.
Be sure to lube up the o-ring with some p/s fluid, petroleum jelly (this is what I prefer to use), etc. in the hopes of not binding/pinching/damaging the o-ring.
Old Sep 23, 2012 | 01:43 AM
innzane's Avatar
Ok, thanks for the info. One ring and lube it.
I will look for a metric pack, the standard was a hair shy.
I doubt the dealer will gouge me much if I have to order it.
Unless they only come in a rebulid kit.
allegedly
Jan 10, 2015 08:45 AM
sickdisco
Jul 17, 2013 06:51 AM
Kalel
Mar 18, 2012 02:38 PM
WIS ROVER
Sep 17, 2010 09:00 PM
