Help! Exhaust Manifold issue
Old May 10, 2018 | 01:02 PM
CollieRover's Avatar
Default Help! Exhaust Manifold issue
Hey Guys,
I am putting my Exhaust manifolds on and the Drivers Side is not lining up. I bought a use one as my original was damaged. Am I screwed? I have bolts 1,2,3 in, but four won't go.
Old May 10, 2018 | 01:29 PM
Never mind I got it on, this kicked my butt a little.
Old May 10, 2018 | 01:41 PM
So, the # 4 bolt was not lining up, prolly had a hard time as the heads are on the engine. First, chase the holes! Second, I got 1,4,8, 6 in followed by the bottom.
First butt kicking today.
Old May 10, 2018 | 04:07 PM
jamestfl's Avatar
This is def the time to take your time, step away for a moment if needed, double check everything. Keep at it!
Old May 10, 2018 | 04:15 PM
Yeah, this was the first time I have had to really reevaluate and try a few different things.
The Bolts were difficult to get in so I added a middle torque sequence/ I did 11, 20, 28 instead of just 11 and 28. Might have been a good Idea to do them before installing the head gaskets, but without a tool bench and garage that would have been very challenging.
Old May 10, 2018 | 11:50 PM
No Doubt's Avatar
I don't think that you *can* install the exhaust headers before the head gasket!
Old May 11, 2018 | 02:46 AM
The Deputy's Avatar
^^^correct.
Old May 11, 2018 | 05:12 AM
Doesn’t he do that in the AB video? I could be wrong.
Old May 11, 2018 | 08:50 AM
Saturnine's Avatar
AB vid has the manifolds attached to the heads for removal and install.
Old May 11, 2018 | 09:44 AM
Fast951's Avatar
Be careful installing the exhaust manifold gaskets, it is very easy to get them turned around and put them on backwards. Be sure to use Never-Seez on the bolts.
