Help! Exhaust Manifold issue
Old May 11, 2018 | 03:10 PM
CollieRover's Avatar
Originally Posted by Fast951
Be careful installing the exhaust manifold gaskets, it is very easy to get them turned around and put them on backwards. Be sure to use Never-Seez on the bolts.
I got them in the right orientation. I used new bolts, and they had loctite/adhesive so no seize was not an option. At least I don't think it was.
Old May 11, 2018 | 03:15 PM
Jeff Blake's Avatar
I put copper anti-seize under the bolt head flange and shoulder, as well as the mating surfaces of those spacers.
Also copper spray a gasket for the exhaust manifold gaskets
Old May 11, 2018 | 05:05 PM
The Deputy's Avatar
Originally Posted by Saturnine
AB vid has the manifolds attached to the heads for removal and install.
Maybe, I should have elaborated some...
Yes, it can be done...but why anyone in their right mind would want to have a case iron exhaust manifold bolted to an aluminum head...while torquing it down...is beyond me. If folks are doing this, I can understand the poor results being found with head gasket replacement jobs.
Brian.
twaszak
Jul 15, 2012 07:21 PM
liPPy
Sep 7, 2011 02:55 PM
surfoblb
Feb 8, 2011 06:01 PM
Robwsup
Feb 16, 2010 05:06 PM
beavis4g63t
Jul 12, 2005 05:27 PM
