Help! Gear shifting issues
Old Mar 22, 2016 | 05:28 PM
bradleyryanchidester@gmail.com's Avatar
7th Gear
Default Help! Gear shifting issues
I'm working with a Disco 2, I'm having some trouble figuring out what's going on with my automatic tranny.
I've already adjusted the shifter linkage because it wouldn't go into park.
Now it is engaging R but not D,1,2 or 3.
Any ideas? Or advice on places for getting more information about the transmission and linkage?
Thanks in advance.
Old Mar 22, 2016 | 06:04 PM
OffroadFrance's Avatar
In the LR RAVE workshop manual on here online.
Old Mar 22, 2016 | 08:03 PM
7th Gear
Default Wait
WuuuuUUUUHHHHHHH!?
Old Mar 22, 2016 | 08:57 PM
mollusc's Avatar
The RAVE is a compilation of all the Land Rover service manuals. You asked for places to get more information.
Find it for free at www.landroverresource.com
Old Mar 22, 2016 | 10:45 PM
LR03NJ's Avatar
If you have a scanner and having some P0705, Then it might be the transmission switch. If you adjust the cable, the switch beside the transmission moves to another position which sometimes end up selecting another gear. PDF below
File Type: pdf
Old Mar 22, 2016 | 11:29 PM
number9's Avatar
Cable - selector
Check
1. Position vehicle on ramp.
2. Select position 'P'.
3. Loosen selector cable trunnion nut.
4. Ensure that gearbox selector lever is in 'P'
position, (fully forward) and tighten trunnion
nut.
5. Lower ramp.
Simple & 2nd page just for reference, don't remove 'C' clip.
File Type: pdf
baghdadi
Jan 18, 2015 02:23 AM
kristoffersmith
Aug 13, 2013 04:40 AM
tom123
Jan 3, 2012 07:20 PM
stu44mag
Dec 2, 2010 10:11 AM
Bivwak2000
Jul 7, 2008 01:09 PM
