Help, have springs, but air supply unit is apprently still active!
For the last couple of months, there has been a whirring sound when ignition key is turned off....lasts a few seconds. The other day, it kept making the whirring sound and didn't stop. My husband found the air supply unit and it was hot to the touch...I think he had to disconnect the battery to make it stop....When someone (previous owner) changes from the air bags to springs, how do they by-pass the air supply unit, or disconnect it? Thanks in advance for any help.
Open hood. Remove one of these two black wires (C0811). One runs fuel pump (it has to be there). The other is the common ground for the SLS pump and valves which will run in the middle of the night to maintain a level vehicle in case Her Royal Highness should wish to make an emergency pedicure run. On page 68 of the circuits manual, bottom right.
The valves will actualy kill the battery after a while.
The reference to HRH is of course to the British Royal family, they sport about in a number of armoured Rovers (mpg in the single digits I bet).
Maybe you will get a light. The sensors are three wires each (power, ground, and signal); and the RAVE says:
Seems like if unplugged, that would be zero volts, so a warning lamp should be on. However, perhaps some resistors could be attached to "fake" a normal reading for the sensor, and then, like Spike says, no light and no problems.
Failure modes
Failures are indicated by the SLS warning lamp in the bottom left corner of the instrument pack illuminating continuously in an amber colour. The following tables show the type of system failures and their effects on the system operation.
Failure Effect
Sensor output stuck at 5 V Vehicle will not level
Sensor output stuck at 0 V Vehicle will not level
Mechanical link between radius arm and sensor
brokenSensor output stuck at 5 V Vehicle will not level
Lincoln Tarantino
05-07-2012 12:37 AM
Sidewinder6
06-09-2010 11:52 AM
Spensive
03-19-2010 06:36 AM
