Help identifying what is leaking
Old Sep 3, 2012 | 05:27 PM
primussucks's Avatar
So I got e everything torn apart with the help of a buddy and some beers.
Got all the way to the bottom and realized that the end seals were not in the box with the valley pan gasket, so i am stuck for the weekend. I found the two end bolts that hold the clamps and seals in were barley finger tight. The seals were cracked and practically crumbled in my hands. I presume this is where I was leaking from
Sitting here with a laid up truck, i'm wondering if there is anything i should do to clean things while i'm waiting?
https://picasaweb.google.com/lh/phot...eat=directlink
Or should I not worry about it?
I plan on doing an oil change when it is back together.
So far the list of items that will be completed on this interval:
-throttle body gasket (along with a cleaning)
-throttle body heater gasket
-valley pan and seals
-upper manifold
-plugs
-wires
-new negative cable (i broke mine)
-valve cover gaskets (almost lost one of the little washer things in the rocker, but found it with a magnet, close call)
I do notice some oil in the IACV, should I replace the PCV valves as well? I saw something about an oil separator, but don't see that in the RAVE.
Where are those notches someone mentioned, about sticking a wire through to make sure they are not plugged? Can someone point them out on one of the pictures?
I was having a ticking sound, which I attribute to a lifter. besides replacing them, anything I can do to give them a scrubbing since its open?
I will be replacing the oil with 15w40 Rotella T.
Thanks for the help folks.
drowssap
Mar 18, 2011 05:24 AM
Cyberbaker
Jan 4, 2011 06:10 PM
rizlagreen
Nov 1, 2010 02:00 PM
Vicks
Mar 14, 2010 12:21 PM
bigugly82
Dec 18, 2007 10:49 PM
